  3. Electrical constraint
  • Views 15380
malih
malih over 17 years ago
I want define a Electrical constraint for a critical net or component for example maximum or minimum delay by axl functions.
please help me
Thank you
Mali
  • nramesh2244
    nramesh2244 over 17 years ago
    In Capture CIS,
    selecty net --> Edit properties - - > filtered by 'xxx'
    Select xxx as cadence - allegro --- Now there are many properties visible.You can add it above details....
  • malih
    I want define a Electrical constraint by axl functions in skill.
  • Ejlersen
    Ejlersen over 17 years ago
    I would advise you too look at all the axl commands starting with axlCNS in the folder installdir\share\pcb\examples\skill\DOC\FUNCS
    Amongst these you'll find axlCNSEcsetCreate that you can use to create an electrical cset, then use axlCNSEcsetValueSet to set constraint values inside this ECSet
    Best regards,
    Ole
  • malih
    Hi Ole
    thanks for the tip.
    Best regards,
    Mali
