  3. Getting area of shape
  • Views 15897
Ejlersen
Ejlersen over 17 years ago
Does anyone know of a command to get the area of a shape?
If I do a display -> element inside PCB Editor and select e.g., a placebound_top then one of the informationsshown is the area of the shape.
Best regards,
Ole
  • kerchunk
    kerchunk over 17 years ago
    Hi Ole,
    create a polygon object from the desired shape object then grab the area property of the poly object
    shape_poly = car( axlPolyFromDB( your_shape_dbid))
    shape_area = shape_poly->area
    HTH,
    Chris Walters
    local Cadence guru
  • Ejlersen
    Hi Chris,
    Thanks for your suggestion, I'll try that out.
    Best regards,
    Ole
