  3. Map functions
  • Views 15948
Map functions
aCraig
aCraig over 17 years ago
Has anybody had trouble nesting map functions? Or is it even valid to do so? I'm running APD L 16.01.
This code works fine to create a flat list to the children of a net.
children =  mapcar(lambda((b) b->children) net->branches))
children =  mapcan(lambda((c) c) children)
if I try to nest the two it hangs the tool.
children =  mapcan(lambda((c) c) mapcar(lambda((b) b->children) net->branches))
  • DE202408202727
    DE202408202727 over 17 years ago
    The following code works in Allegro:
     mapcan(lambda((c) c) mapcar(lambda((b) car(b)) '(((1 2) 3)((4 5) 6)((7 8) 9))))
    It returns (1 2 4 5 7 8) as predicted.
    Your nested net function also works in Allegro 16.2.
  • aCraig
    Dave, this works for me as well.
    I'm not sure what's going on. If I select a net with more then 1 branch and then execute the command it runs fine the first time. If I execute it a second time it locks up APD. If I select a net with only 1 branch it runs multiple times, no problem.
     EDIT: behaves the same way in Allegro 16.01 XL
  • DE202408202727
    Oh yes.
    I see the same thing in Allegro with a multi-branch net but not with the above example.
    I'm not sure what would cause this.
    Dave
  • aCraig
    So I believe I've figured out what the heck is going on (although it doesn't make sense)!
    Using Dave's example (broken down):
    mylist =  '(((1 2) 3)((4 5) 6)((7 8) 9))
    newlist = mapcar(lambda((b) car(b)) mylist)
    At this point:
    mylist =  '(((1 2) 3)((4 5) 6)((7 8) 9)); this is correct
    newlist = '((1 2) (4 5) (7 8)); this is correct
    All is good until:
    flatlist = mapcan(lambda((c) c) newlist)
    flatlist = '(1 2 4 5 7 8); this is correct
    newlist = '(((1 2 4 5 7 8) (4 5 7 8)  (7 8)); I beleive this is correct since mapcan uses the destructive function nconc.
    mylist = '(((1 2 4 5 7 8) 3) ((4 5 7 8) 6) ((7 8) 9)); this is what's confusing. why has mylist been modified??
    This brings me to my original problem:
    This command is actually destructively replacing the children in the net branch structure. This is the reason, I believe, the tool is hanging. The next time you try to access the net dbid structure everything is out of wack. The bad structure is not saved when you save the design, luckily.
