  3. How to detect a progress meter
  • Views 15082
GregC
GregC over 17 years ago
Does anyone know how to detect if a meter is already running?
I found a situation where if a second meter is launched the first one becomes disconnected.  It can't be updated or destroyed.
To test:
axlMeterCreate( “Meter1” “info line” t ) ; now you will see a meter
axlMeterCreate( “Meter 2” Info Line” t ); now you see the second
axlMeterDestroy()  ; this will kill the second meter you will see the first
axlMeterDestroy()  ; no matter how many times you try to kill the meter the first one won’t go away.
Any help would be appreciated.
  • aCraig
    aCraig over 17 years ago
    Greg, I don't believe this is possible since axlMeterCreate doesn't return a form id. So there is no way to selectively destroy a meter. It appears that only a single meter id is supported.
     Craig
  • GregC
    Thanks Craig,
    I was hoping to see if a meter is already running so I wont start a second.  I wanted to know if I can detect if a meter is already running so I can put a when/ unless condition around the other axlMeterCreate. eg unless( meter axlMeterCreate( x y t ) ).  Too bad the axlMeterCreate doesn't return a dbid.
    Greg...
  • aCraig
    You might try using a variable to manage this
    myMeter = nil
    axlMeterCreate(...)
    myMeter = t
    unless(myMeter
        axlMeterCreate(...)
  • aCraig
    So I found were the meterForm Id is.
    formId = axlUIGetUserData()->meterForm.
    If there is an activer meter you will get the form id.
