  3. Removing Same Net Spacing csets from Constraint Manager...
  • Views 15135
Removing Same Net Spacing csets from Constraint Manager using skill
mr wilson
mr wilson over 17 years ago
I'm working on some skill code to remove everyting from the CM leaving just the bare nets.  So far I have been able to use the new Cns and old CNS functions to remove all but a couple of properties  I deal with them using axlDBDeleteProp.  I can't seem to make the Same Net Spacing rules go away.  The docs say that these csets are part of the spacng domain but the are not deleted by using the axlCnsPurgeCsets command.  Is there a way to tell if a cset is a SNS set?  If I could tell the type, I could use the axlCNSSetSameNet to set them all to the Default.  Still not sure I will be able ot delelte them because the are still assigned to the "DEFAULT" cset.
Mike Wilson,
Dell Inc.
  • fxffxf
    fxffxf over 17 years ago
     allegro requires a DEFAULT cset for spacing, physical and samenet domains so the last cset cannot be delete.
