  3. check the existance of the worldview window in skill?
  • Views 14943
djhutchi
djhutchi over 17 years ago
I have some skill code the appears to run very slowly when the worldview window is visable, however I can't seem to find any standard axl??? skill procedure that check the existance of that window, any ideas?
TIA
Dave
  • aCraig
    aCraig over 17 years ago
    Use axlGetVariable(nil) for a list of variables you can set in Allegro/APD. I believe axlSetVariable("WORLDVIEW_DISABLE" nil) will turn it off.
     Craig
