  3. Local variables to multiple procedures in an il file
  • Views 18333
skillnewbie
skillnewbie over 17 years ago
I have an il file which consists of two procedures, it looks like this:
procedure( myProcedureA()
                let((varA varB)
                     procedureB()
procedure( myProcedureB()
                let((varC varD)
                     skill coding...
in this case, varA and varB belong to prcedureA while varC and varD belong to procedureB.
after either procedureA or B is executed, they become "unbound", which means at Skill Shell, we type
"Skill> println(varA) " we shall get an "unbound variable" message.
I want to have a glabal variable (that's say varE) which can be shared by both procedures A and B,
However, I want to make it local to A and B only, which means after A and B are executed (since A will call B),
when we type "Skill> println(varE)" it shall produce an "unbound variable" message.
How shall I go with it? Thanks~
  • fxffxf
    fxffxf over 17 years ago
     If assigning attributes to the form handle, myform, it is best if you prefix your attribute name with an underscore so your variables will not conflict with existing or future form handle attributes.
    Example
     myform ->_list1 = '(a b c d)
