  3. Local variables to multiple procedures in an il file
  • Views 18332
skillnewbie
skillnewbie over 17 years ago
I have an il file which consists of two procedures, it looks like this:
procedure( myProcedureA()
                let((varA varB)
                     procedureB()
procedure( myProcedureB()
                let((varC varD)
                     skill coding...
in this case, varA and varB belong to prcedureA while varC and varD belong to procedureB.
after either procedureA or B is executed, they become "unbound", which means at Skill Shell, we type
"Skill> println(varA) " we shall get an "unbound variable" message.
I want to have a glabal variable (that's say varE) which can be shared by both procedures A and B,
However, I want to make it local to A and B only, which means after A and B are executed (since A will call B),
when we type "Skill> println(varE)" it shall produce an "unbound variable" message.
How shall I go with it? Thanks~
  • Anton
    Anton over 17 years ago
    You can have varE in the let statement for myProcedureA, and then passed as an argument to myProcedureB:
                    let((varA varB varE)
                         procedureB(varE)
    procedure( myProcedureB(varE)
                    let((varC varD)
                         skill coding...
  • DE202408202727
    DE202408202727 over 17 years ago
    You're in luck. You don't need to do anything. The local variables in the calling procedure are available in the called procedure.
    Try it!
    eg:
    procedure( myProcedureA() let((varA) varA = 123 myProcedureB()))
    procedure( myProcedureB() let((varC varD) println(varA) ))
    myProcedureA()
    123
    println(varA)
    E- *Error* eval: unbound variable - varA
    ERROR
  • skillnewbie
    hi eDave and Anton,
    Thanks for the solution, i tried both of them and it works~
    appreciate your help on this.
  • skillnewbie
    hi,
    actually my coding problem is like this:
    I open a form handle in procedureA
    procedure( procedureA()
    let( (list1 list2 myform)
                 list1 = '(a b c d)
                 list = '(e f g h)
                  myform = axlFormCreate((gensym) "anyform.form" '("E" "OUTER")   '_ncAction t)
    I want to pass the list1 and list2 (which are defined from procedureA) to the form action procedure "_ncAction" but I want to make them (list1, list2 and myform) local to the 2 procedures only. so I define this in my _ncAction...
    procedure(  _ncAction(ncform list1 list2)
     and an error message is shown "_ncAction: too few arguments (3 expected, 1 given) " . It seems that list1 and list2 are NOT passed to the form action (_ncAction) procedure... is it possible to overcome this?
    Thanks again for help~
  • DE202408202727
    Try this method:
    myform ->list1 = '(a b c d)
    myform ->list = '(e f g h)
    in your callback funtion you can retrieve the lists by using:
    ncform ->list1 and ncform ->list
