  3. SPB 16.2 DRC Walk
  • Views 14256
SPB 16.2 DRC Walk
aquagarrett
aquagarrett over 17 years ago
My DRC Walk skill no longer works with 16.2.  I recently moved from 15.7 to 16.2. I am guessing the new constraint approach is not allowing the script to work.  Is there an updated DRC Walk or something similar that someone would recommend?  I notice the DRC checking within the constraint manager but I do not like it as much as I liked DRC Walk.  Thanks.
  • luanvn81
    luanvn81 over 17 years ago
     Hi! I think you should check the folder where DRCWalk.il file is located. If not be there you should copy DRCWalk.il file to pcbenv folder .In 16.2 this file must be in pcbenv folder ( ex:D:\ Home\Pcbenv).
