  3. route>slide axl-command??
  • Views 2687
sepiroth
sepiroth over 17 years ago
 Hi, any axl-command can run the slide (route>slide) function to slide the clines?
 If no is there any other alternative way to do it?
sepiroth
  • sepiroth
    sepiroth over 17 years ago +1
    Hi djhutchi , The provided code as below is work on shoving the clines on via. Can the code be modified so the slided distance can be set? Example, the clines want to be slide ix 100…
  • ubaid
    ubaid over 17 years ago
    Shift+F5 (If using <16.0)
    Shift+F3 (For 16.X verstions)
    Ubaid Warsi
  • sepiroth
     Hi Ubaid,
     Those are the aliases function key. What I looking for is the axl-command that I can use when writing the SKILL programming.
    Anyone try to slide the traces by using SKILL programming before?
  • djhutchi
    djhutchi over 17 years ago
    Below is a small code segment that uses the axl funcitons to attempt sliding clines to clear DRC violations on vias that were just added:
                                            axlMsgPut("Shoving %d Clines" length(clines))
                                            axlShoveSetParams(list(1 45 1 1 0 0))
                                            unless(axlShoveItems(clines)
                                                axlDeleteObject(via)
                                                axlMsgPut("Via deleted due to Shoving Error")
  • sepiroth
     Hi djhutchi,
    The provided code as below is work on shoving the clines on via. Can  the code be modified so the slided distance can be set? Example, the clines want to be slide ix 100 from its original place.
        axlSetFindFilter(?enabled '("CLINES" "VIAS") ?onButtons '("CLINES" "VIAS"))
        axlSelect()
        axlShoveItems(axlGetSelSet())
