  3. Executing/Loading SKILL scripts after PCB editor has come...
  • Replies 7
  • Views 9194
Executing/Loading SKILL scripts after PCB editor has come up
ddbarge
ddbarge over 17 years ago
I have written some SKILL scripts and added their entries in allegro.ilinit. These scripts run fine when PCB Editor is coming up.
But now I have an requirement that I want to run some SKILL scripts after the PCB Editor has come up. These scripts manipulate the .BRD files automatically without any user intervention. Also since these scripts use axlXXXX functions I cannot add these scripts in allegro.ilinit
Can anyone provide help on
1) Is there a way to execute/load SKILL scripts after the PCB editor has come up (I know we can do it by typing [skill load "<filename>" ]
    But it needs the user to type this in the PCB command interpreter. But I need automated way of calling my scripts
  • DE202408202727
    DE202408202727 over 17 years ago +1
    You might want to take a look at the axlTriggerSet function.
  • ddbarge
     Thanks Dave for the help!!
    The triggers work fine and I am able to execute scripts as and when a new BRD file is opened or closed
     I had a small quick question for you please
    I was trying to find a way using SKILL function so as to call an executable (some .exe) from within a SKILL script  .....
    Thanks again for the help
  • DE202408202727
    There are several methods::
    I generally use "system()" (easiest) or "axlRunBatchDBProgram".
