  3. Executing/Loading SKILL scripts after PCB editor has come...
  • Replies 7
  • Views 9193
Executing/Loading SKILL scripts after PCB editor has come up
ddbarge
ddbarge over 17 years ago
I have written some SKILL scripts and added their entries in allegro.ilinit. These scripts run fine when PCB Editor is coming up.
But now I have an requirement that I want to run some SKILL scripts after the PCB Editor has come up. These scripts manipulate the .BRD files automatically without any user intervention. Also since these scripts use axlXXXX functions I cannot add these scripts in allegro.ilinit
Can anyone provide help on
1) Is there a way to execute/load SKILL scripts after the PCB editor has come up (I know we can do it by typing [skill load "<filename>" ]
    But it needs the user to type this in the PCB command interpreter. But I need automated way of calling my scripts
  • DE202408202727
    DE202408202727 over 17 years ago +1
    You might want to take a look at the axlTriggerSet function.
  • DE202408202727
  • pcbgeorge
    pcbgeorge over 17 years ago
    You just have to include a call to your startup function as the last line in your program, and outside any functions.  Place the program as the first in your allegro.ilinit and it will load and execute that last line.  I use something like this to add local menus to the stock menus before Allegro needs them.
    ; This is an example program, not that
    ; there is no axlCmdRegister definition.
    (defun firstFunction ()
    ); end-defun
    (defun secondFunction ()
    ); end-defun
    (defun thirdFunction ()
    ); end-defun
    (printf "myProgram loaded...\n")
    ; This calls the firstFunction after
    ; everything else is loaded.
    (firstFunction)
    ; End-Of-File
    George Patrick
    Tektronix, Inc.
    Central Engineering, EDS Applications Support
  • pcbgeorge
    I may have misunderstood.  If you want to run an Allegro script on startup (not a SKILL program), you can start Allegro with the -s command line switch:  "allegro -product PCB_design_expert -s scriptname[.scr]"
    George Patrick
    Tektronix, Inc.
  • ddbarge
     Thanks Dave and George for the prompt replies.
          I will follow up with you Dave if I need some pointers. For now can you tell me where should this trigger registration code go into, I am perplexed because using axlTriggerSet() which is essentially a SKILL function cannot be used in any scripts that are mentioned in allegro.ilinit (this is what is my understanding.
         @George: Well I dont want to execute any .scr but SKILL programs, but thanks for the suggestion. Please let me know if there are any other pointers.
            As Dave said, I think axlTriggerSet() looks promising.
  • DE202408202727
    Place your axlTriggerSet command in your allegro.ilinit file.
    I have this command in my ilinit file: axlTriggerSet('open 'tait_OpenAllegroTrigger)
    tait_OpenAllegroTrigger is a function in a Skill file that has already been loaded by the ilinit file.
