  3. Calling an external executable[.exe] using SKILL
  • Subscribers 166
  • Views 17932
ddbarge
ddbarge over 17 years ago
I was trying to find a way using SKILL function so as to call an executable (some .exe) from within a SKILL script  .....
Can anyone direct me some help/pointers
Thanks again for the help
  • skillUser
    skillUser over 17 years ago
    first the disclaimer, I work with SKILL in the Custom IC (CIC) tools, though it is very similar.
    You can either use one of the sh(), csh(), or shell() commands to initiate an external job, or you can use the ipc* commands such as ipcBeginProcess(), ipcSkillProcess(), or ipcBatchProcess(). Use the latter if you need to communicate with the job/process, or the former approach if you can just start the job and don't need to send anything to it or receive any output from it.
    Hopefully this answers your question.
    Lawrence.
  • imagesensor123
    imagesensor123 over 15 years ago
       yes, we can use the Ipc command to communicate with the external tool, especially the .exe file. but here, i met a problem, i want to call the "gimp" a system viewer tool (view image) in linux, and i want to call it in my form by pushing a button, so can you give me some opinions?
    zfeng
  • imagesensor123
    i used a  command in the CIW  like this icpBeginProcess("eog filename"), it works very well.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    You could use axlRunBatchDBProgram
    Best regards
    Ole
