  3. Turning enclosed lines into a shape?
  • Replies 15
  • Subscribers 167
  • Views 26341
EvanShultz
EvanShultz over 17 years ago
 Is there an existing way (I will assume using SKILL) to turn an area enclosed by lines into a shape on any given layer? In my specific application, I am bringing in a DXF drawing and I'd like to take the areas in the DXF file and make them shapes.
  • DE202408202727
    DE202408202727 over 15 years ago
    See attached. Note that there are a couple of Right-Mouse-Button options to select the kind of conversion required. Dave
    clineToShape_public.zip
  • littleanne
    littleanne over 15 years ago
     Dave,i'm still using cadence 16.2. Do u have the code for 16.3 and below?
  • DE202408202727
    Hi Anne, See attached. The code was written in 2005 but it should work OK. Dave
    cl2s.1.3.released.zip
  • jtra
    jtra over 10 years ago
    Hi Dave, I'm trying to re-tool this to convert lines on Assembly, and compose to shape on DFA layer. Can you please give soem guidance? Thanks!
  • DE202408202727
    DE202408202727 over 10 years ago
    You probably shouldn't use this tool if you are trying do do what I suspect. You have an assembly outline (drawn as a zero-width path) and you want to use it as the (filled) shape outline on the DFA layer. Right?
