  3. Turning enclosed lines into a shape?
  • Replies 15
  • Subscribers 167
  • Views 26348
EvanShultz
EvanShultz over 17 years ago
 Is there an existing way (I will assume using SKILL) to turn an area enclosed by lines into a shape on any given layer? In my specific application, I am bringing in a DXF drawing and I'd like to take the areas in the DXF file and make them shapes.
  • jtra
    jtra over 10 years ago
    Yes. Idea I had is to leverage data on Assembly layer and convert that to DFA shape. This is because some footprints are missing the DFA layer. Thanks!
  • DE202408202727
    DE202408202727 over 10 years ago
    This function should help you:
    defun( DE_ConvertLineToShape (lineDBID, shapeLayer)
    when(lineDBID ->objType == "path" && onep(lineDBID ->nSegs) && lineDBID ->hasArcs || lineDBID ->nSegs > 2 && axlGeoPointsEqual(car(car(lineDBID ->segments) ->startEnd), cadr(lastelem(lineDBID ->segments) ->startEnd))
    path = axlDB2Path(lineDBID)
    poly = car(axlPolyFromDB(path))
    axlDBCreateShape(poly, t, shapeLayer)
  • jtra
    That worked great! I just edited a bit to fit our scheme. Thanks so much!
    procedure( DE_ConvertLineToShape()
    let((lineDBID, shapeLayer, poly, path)
    axlSetFindFilter( ?enabled '( "noall" "lines") ?onButtons '( "noall" "lines" ))
    lineDBID = axlGetSelSet(axlSingleSelectBox())
    shapeLayer = "PACKAGE GEOMETRY/DFA_BOUND_TOP"
    when(lineDBID
    foreach(item lineDBID
    item ->objType == "path" && onep(item ->nSegs) && item ->hasArcs || item ->nSegs > 2 && axlGeoPointsEqual(car(car(item ->segments) ->startEnd), cadr(lastelem(item ->segments) ->startEnd))
    path = axlDB2Path(item)
    );foreach
    ); when
    );let
    );proc
  • cykoay
    cykoay over 9 years ago
    hi Dave,
    I tried to select all non-closed line for on board logo using your clineToShape_public.il but seems like it is not successful with error message"no cline/line(without arc segments) here, is it this script cannot support non-closed intersected line shape?
  • DE202408202727
    DE202408202727 over 9 years ago
    That utility is intended for converting clines (with a width) into shapes.
