  3. how can I get a list of text dbids?
  • Views 16668
Ejlersen
Ejlersen over 17 years ago
Hi
Does anyone know a function to get a list of text dbids?
  • DE202408202727
    DE202408202727 over 17 years ago
    axlClearSelSet()
    axlSetFindFilter(?enabled list("noall", "text", "invisible"), ?onButtons list("noall", "text"))
    axlAddSelectAll()
    selSet = axlGetSelSet()
  • Ejlersen
    Hi Dave
    Thanks for your answer. I'll try that out.
    I've tried a couple of times to save the settings of the Find panel and restoring it without any luck, do you have any tips regarding this?
    Best regards
    Ole
  • aCraig
    aCraig over 17 years ago
        ; Save the mini status form information
        userData = axlUIGetUserData()
        putprop(userData axlVisibleGet() 'visibility)
        putprop(userData axlGetFindFilter(nil) 'FFEnabled)
        putprop(userData axlGetFindFilter(t) 'FFOnButtons)
        ; Restore mini status form data
        axlVisibleSet(userData->visibility)
        axlSetFindFilter(?enabled userData->FFEnabled,  ?onButtons userData->FFOnButtons)
        axlClearSelSet()
    -Craig
  • DE202408202727
    I don't know who wrote these functions originally, but they are now in common use:
    ;Saves the select set options:
    defun( _saveSelSet () list(axlGetSelSet(), axlGetFindFilter(nil), axlGetFindFilter(t)))
    ;Restores select set options:
    defun( _restoreSelSet (oldSelSet "l")
      axlSetFindFilter(?enabled cons("noall", cadr(oldSelSet)) ?onButtons cons("noall", caddr(oldSelSet)))
      axlSingleSelectObject(car(oldSelSet))
      t
    Regards, Dave
  • aCraig
    Dave,
    Those look like private Cadence functions, as the start with an underscore. It's doing essentially the same thing I suggested, except instead of putting 3 properties on axUIGetUserData it putting one (oldSelSet). If you look at axlUIGetUserData after you run _saveSelSet you will see what I mean.
    -Craig
