  3. Change text height
  • Views 14844
Change text height
steve
steve over 17 years ago
Does anyone know if there is any skill code avaliable to change the text block height of specifc groups of components ? What I want to do is only select components with a refdes of R or C and increase or decrease their text block height.
  • DE202408202727
    DE202408202727 over 17 years ago
    Hi Steve,
    The following snippet might help you.
    Cheers, Dave
    defun( replaceRefdesTextHgt (refdesPrefixString, newTextBlock, layer, "ttt")
     let((txtObjs, txtOrient, result, (n 0))
      axlClearSelSet()
      axlSetFindFilter(?enabled list("noall", "invisible", "text"), ?onButtons list("noall", "text"))
      axlAddSelectAll()
      txtObjs = setof(dbid, axlGetSelSet(), dbid ->layer == layer && dbid ->textBlock != newTextBlock && rexMatchp(strcat(refdesPrefixString, "[0-9]+[.]*"), dbid ->text))
      axlClearSelSet()
      foreach(txtId, txtObjs
        txtOrient = make_axlTextOrientation(?textBlock newTextBlock, ?rotation txtId ->rotation, ?mirrored txtId ->isMirrored, ?justify txtId ->justify)
        result = axlDBCreateText(txtId ->text, txtId ->xy, txtOrient, txtId ->layer, txtId ->parent)
        when(result, axlDeleteObject(txtId), n++)
      n
    Usage example: replaceRefdesTextHgt("C", "18", "REF DES/ASSEMBLY_TOP")
  • oldmouldy
    oldmouldy over 17 years ago
    Hi Dave,
    Another spectacular insight into SKILL, I guess it must be mid-winter for you which is how come you have the time to invent all this stuff!
    Many thanks for all of your contributions!
