  3. how to assign cset to netclass using skill
  • Replies 7
  • Subscribers 166
  • Views 19317
Ejlersen
Ejlersen over 17 years ago
Hi
Anyone knows if there is an axl function to assign a named constraint set to a specific netclass?
Added 26th of June: I've figured out how to do this using script, but would prefer not to do it using scripts.
Best regards
Ole
  • asedehi99
    asedehi99 over 17 years ago
    any luck?
  • fxffxf
    fxffxf over 17 years ago
     this cannot be done using pure skill code.
  • Ejlersen
    Hi
    Yes I had luck, I recorded a script and in my skill code I'm writing scripts and replaying them.
    Although I would prefer to use skill this is acceptable and works very well.
    Best regards
    Ole
  • Jmus
    Jmus over 17 years ago
    Hi
    What kind of script did you use to assign the cset to a netclass?  I have a external list of net class spacing requirements in the form of a .txt file that I plan to import with skill code. Acorrding to previous posts it appears there is no way to assign the csets to netclasses in skill. How do you pass the cset and netclasses you want to alter with your script?
    I'm not sure what I'm trying to do is the same as what you were doing so I will clarify.  I have netclasses set up in the PCB constraints manager already which have been imported from an OrCAD/Capture schematic. I need to establish spacing rules between netclasses for a high voltage design process where for example one netclass may be a DC bus and another Chassis and I have a precalculated number which I need to enter as a clearance.
     JM
  • Ejlersen
    Hi
    I'm using this to parse a number of text files extracted from Excel, I cannot give the code away yet since it is part of a constraint initiative my company is working on for the benefit of Danish electronics developement companies.
    Basically I've got 2 procedures, one to assign spacing and physical cset to a netclass and another procedure to create netclass 2 netclass constraints. The 2 procedures are below. You just need a header and a footer for the script file.
    use file, script to record a script where you do what you want and then you just need to save data to a script and then replay it, example below
       tmp_file = axlDMOpenFile("ALLEGRO_SCRIPT", "tmp", "w")
       fprintf(tmp_file "scriptmode +i +n +w +c\n")
       fprintf(tmp_file "setwindow pcb\n")
       fprintf(tmp_file "done\n")
       fprintf(tmp_file "cmgr\n")
       fprintf(tmp_file "setwindow cmgr\n")
       fprintf(tmp_file "cm newView ( worksheet 55:Physical \"56:Physical Constraint Set\" \"57:All Layers\" \"58:All Layers\" )\n")
       fprintf(tmp_file "cm newView ( worksheet 55:Physical 61:Net \"62:All Layers\" \"63:All Layers\" )\n")
       fprintf(tmp_file "cm newView ( worksheet 78:Spacing \"79:Spacing Constraint Set\" \"80:All Layers\" 81:Line )\n")
       fprintf(tmp_file "cm newView ( worksheet 78:Spacing 94:Net \"95:All Layers\" 96:Line )\n")
       fprintf(tmp_file "cm scope Design \"%s\"\n" axlCurrentDesign())
       ns_map_cset2netclass(spacingCset recordid physicalCset)
       fprintf(tmp_file "cm exit\n")
       axlDMClose(tmp_file)
       axlShell("replay tmp")
       if( isFile( "tmp.scr") then deleteFile("tmp.scr"))
    ; --------  arg1 = spacing Cset name, arg2 = Netclassname, arg3 = Physical Cset name
    procedure( ns_map_cset2netclass( arg1 arg2 arg3)
    let((nc_domains)
      nc_domains = '(spacing physical)
      axlNetClassCreate(arg2 nc_domains)
      fprintf(tmp_file "cm startTransaction ( Design \"%s\" ) ( \"Net Class\" \"%s\" ) TS_DEFER\n" axlCurrentDesign() arg2)
      fprintf(tmp_file "cm add ( \"Net Class\" \"%s\" ) to ( \"Spacing CSet\" \"%s\" )\n" arg2 arg1)
      fprintf(tmp_file "cm commitTransaction ( Design \"%s\" ) ( \"Net Class\" \"%s\" ) TS_DEFER\n" axlCurrentDesign() arg2)
      fprintf(tmp_file "cm add ( \"Net Class\" \"%s\" ) to ( \"Physical CSet\" \"%s\" )\n" arg2 arg3)
    ); end procedure
    ;  --------  arg1 = col_name, arg2 = row_name, arg3 = Spacing Cset name
    procedure( ns_netclass2netclass( arg1 arg2 arg3)
    let((nc_domains)
      fprintf(tmp_file "cm create \"Net Class-Class\" ( Design \"%s\" ) \"%s:%s\" \"%s\" \"%s\"\n" axlCurrentDesign() arg1 arg2 arg2 arg1)
      fprintf(tmp_file "cm startTransaction ( Design \"%s\" ) ( \"Net Class-Class\" \"%s:%s\" ) TS_DEFER\n" axlCurrentDesign() arg1 arg2)
      fprintf(tmp_file "cm add ( \"Net Class-Class\" \"%s:%s\" ) to ( \"Spacing CSet\" \"%s\" )\n" arg1 arg2 arg3)
      fprintf(tmp_file "cm commitTransaction ( Design \"%s\" ) ( \"Net Class-Class\" \"%s:%s\" ) TS_DEFER\n" axlCurrentDesign() arg1 arg2)
    ); end procedure
    Best regards
    Ole
