  3. case insensive text compare - Solved - Use upperCase fu...
  • Views 2034
case insensive text compare - Solved - Use upperCase funtion
Ejlersen
Ejlersen over 17 years ago
Hi
Normally the text compare is case sensitive but I'm looking for a function to compare without looking at the case.
So basically "TEST" is equal to "Test" or "test"
Does such a function exist?
Forget my question: I can just use upperCase to convert everything to upperCase before comparing.
Best regards
Ole
  • aCraig
    aCraig over 17 years ago
    Ole,
     How about:
    if( upperCase("Test") == upperCase("test").
     Craig
