  3. Help Needed on New Plugin Development: Cross Probe between...
  • Views 14720
Help Needed on New Plugin Development: Cross Probe between PDF and Allegro
vramanan
vramanan over 17 years ago
Hi Guys
I  am trying to develop a new plugin for Acrobat which will make cross probing from schematic to Allegro easier
 The problem with Concept is you can only select one component at a time
I know that each object in the Schematic PDF has an underlying attribute
I need help/pointers for the following
 1. Is there a way you can communicate between allegro to acrobat both ways? if so any documentation/example
my plan is to grep for $location attribute inside the pdf and convert to lists based upon the user selection, and highlight the components in those lists using Skill
I hope to get some help and pointers in the right direction, and will appreciate any kind of help
p.s.
I know that there is a company who is selling a product like this, But I want to save some money and do some programming
Regards
Venkata
  • Romme
    Romme over 17 years ago
    If You have the Acrobat and it is registered, then go to the Adobe Acrbat forum and user sites to find a lot of Acrobat based script, and then when You do know how to, getting info out of the PDF, then use it in Allegro, but i do belive You have to go through a tmp file.
    Unless... Unless it is possible to controll skills and Allegro behaivior from XML files ?
