  3. axlLoadSymbol from library instead of board
  • Views 14580
Ejlersen
Ejlersen over 17 years ago
Hi
I have a board with a symbol "0805res" but would like to use axlLoadSymbol to load it from the library to get information to compare against the symbol inside the board file.
Is there a way to do this?
Best regards
Ole
  • aCraig
    aCraig over 17 years ago
     Ole,
     Looking at the documentation it appears axlLoadSymbol will always find the symbol in the board file first, before it even looks at the library path. A work around might be
    1) build a list (or table) of symbol information you want to compare in the present deisign.
    2) open a new blank design and load the symbols of interest.
    3) do the comparison
    4) output report
    5) reload design
    -Craig
  • Ejlersen
    Hi Craig
    After writing the post I actually found out that you can use the path when using axlLoadSymbol
    e.g., symdef = axlLoadSymbol("package" "c:/Company/pcb/symbols/1206res")
    So this solves the problem for me, but thanks for your suggestions.
    Best regards
    Ole
