  3. How to get every report using skill language!
  • Views 16870
swin
swin over 17 years ago
hi ,I want to get some reports(for example:unconnect pins reports, component report and so on) in pcb editor,
and  make it by skill
please tell me how to realize it!
  • EvanShultz
    EvanShultz over 17 years ago
     Hi swin,
     I recommend you check out rep_bom_ignore.il from the Allegro_SKILL_Code section of SourceLink. That SKILL file gives you a good example of a custom report and how to integrate it with the other reports within Allegro. It was all I needed to create custom reports.
    If you want the 2 reports you listed, they already exist in Allegro by default under Tools > Quick Reports. If you want the code to create those reports, I don't have it, but using the above example and digging through the SKILL documentation you could re-create the report code.
  • Panglossian
    Panglossian over 15 years ago
    Hi swin,
    "I recommend you check out rep_bom_ignore.il from the Allegro_SKILL_Code section of SourceLink. "
    Wer to find it..am not able to locate it..detailed path description will b appreciable since am new in skill programming..
    Panglossian
  • rong96
    rong96 over 15 years ago
     http://support.cadence.com
    From the Resources menu select SKILL Information
    In the section  Silicon-Package-Board Co-Design select the link Allegro SKILL Code Library
    Look for the description "Create a report and add it to your report lists". The descriptions are in alphabetical order
