  3. How to get the film filename suffixes info?
  • Subscribers 163
  • Views 14782
screen2
screen2 over 17 years ago
Does any one can tell me how to get the "Prefix" and "Suffix" text string data at the "Global film filename  suffixes" field of menu Manufacture > Artwork > General Parameters tab  ?
Thanks in advance,
David Yang
  • leonlee
    leonlee over 17 years ago
     Hi David,
     My suggestion is to use the command axlGetParam:
    p = axlGetParam("artwork")
    p->groupMembers
    It can get all the film name, then you can get the suffix or prefix. FYI.
  • fxffxf
    fxffxf over 17 years ago
    The following will do it
     id = axlDBGetDesign()
    id->prop->ARTWORK_PREFIX
    id->prop->ARTWORKS_SUFFIX
