  3. FORM designer for Skill
  • Replies 22
  • Subscribers 166
  • Views 33176
vramanan
vramanan over 17 years ago
Hi Guys
I was wondering is there is any gui development tools for SKILL, It is very tedious to type the FORM file in BNF format and try to debug it
 I searched in the web to no avail, if anyone knows a tool which will let you design the SKILL forms graphically like the forms designer and output the form file please let me know
 mean while I found out some tools that might be of interest
I used to write automated scripts using Autoit it has a free form designer called KODA
www.autoitscript.com/.../formdesign.html
this will save the form file as a KXF file and which is a XML file and can output an autoit script which is similar to visual basic
If anyone write a script/tool convet the xml to BNF or autoit to BNF that would be great.
for example The output of the koda will look like
$Form1 = GUICreate("Board Template Editor", 752, 561, -1363, 199)
$Tab1 = GUICtrlCreateTab(16, 24, 713, 521)
GUICtrlSetResizing(-1, $GUI_DOCKWIDTH+$GUI_DOCKHEIGHT)
$TabSheet1 = GUICtrlCreateTabItem("Board Details")
$Group1 = GUICtrlCreateGroup("Board Details Input", 32, 64, 681, 449)
$Input1 = GUICtrlCreateInput("Input1", 152, 112, 121, 21)
$Button1 = GUICtrlCreateButton("Button1", 64, 448, 75, 25)
$Checkbox1 = GUICtrlCreateCheckbox("Checkbox1", 128, 384, 97, 17)
$Checkbox2 = GUICtrlCreateCheckbox("Checkbox2", 280, 384, 97, 17)
$Checkbox3 = GUICtrlCreateCheckbox("Checkbox3", 424, 384, 97, 17)
$Button2 = GUICtrlCreateButton("Button2", 160, 448, 75, 25)
$Label1 = GUICtrlCreateLabel("Label1", 80, 120, 36, 17)
$Label2 = GUICtrlCreateLabel("Label2", 80, 152, 36, 17)
$Input2 = GUICtrlCreateInput("Input2", 152, 144, 121, 21)
GUICtrlCreateGroup("", -99, -99, 1, 1)
In BNF it should look like
FORM
FIXED
PORT 80 55
HEADER "Board Template Editor"
TILE
TABSET "Board Details"
FLOC 16 24
TSSIZE 713 521
TAB "Pack_Select"
 Any help/leads on this regard will be much appreciated
  • DE202408202727
    DE202408202727 over 17 years ago
    I always try to build my forms dynamically within my main code. I have written small functions to create each of the form features such as buttons. Using this method, form development is much simplified and easier to maintain. You can find examples of these functions (although most will have been modified for public release) in some of the code I have posted.
  • vramanan
     Hi Guys
    I agree with dave on his point, but then I think it will be easier for a skill developer to see theGUI first to visualize what he/she wants to do
    long story short, I have written a perl script to do some trick
    limitations and usage
    1.  type perl xml2bnf <filein.xml> <fileout.il> ( need XPATH to be installed with PPM)
    2. use  the tool from http://www.autoitscript.com/fileman/users/lookfar/formdesign.html to create the form file, rename the *.kxf to *.xml
    3. place the windows-1251.enc in the same directory as the exe file
    4. You can't put multiple tabs on the same form (not tested)
    5. You can't nest Group under a Group
    6. Only Button/Input/Combo/Radio/Checkbox is supported
    7. I can't figure out to extract Combobox list (appreciate any help)
    but here is the perl file
    regards
     Venakta
    XML2BNF.zip
  • vramanan
     i am attaching the file again
    XML2BNF.zip
  • vramanan
    I am thinking that there is some issue with the attachment so posting the perl code (depedant on XPATH, Math Round)
    i have 2 files in the example_files.zip, one tpages.xml to test the script and windows-1251.enc, you should place it in the same location as that of the script
    Save the following as xml2bnf.pl
    example_files.zip
  • vramanan
     This is the latest version of the Code
    Changes
    1. Support Lists
    2. Support inital value on Edit fields
    3. The form looks similar to the original xml file
    Future Updates likely to include
    1. Support for Multi-Line Text
    2. Support for Grids
    3. unique POP list for every ENUM Field
    Regards
    Venkata
    xml2bnf.zip
