  3. finding vias
  • Views 17539
finding vias
ahmetozsoy
ahmetozsoy over 17 years ago
Hi all,
Is there  a skill program that shows all the vias and via positions? This is because if I want to change a specific via type to another via type I could not manage to find where the via is. This is useful when you use some blind vias and convert them to thru-hole type vias to decrement the cost. In allegro editor reports the tool has the capability to say that there are for ex. 35 items used  for   via_thr_02_30x30 ( name of the via) but could not say its position.
Thank you.
Ahmet OZSOY
  • aCraig
    aCraig over 17 years ago
    Here's some code that will find all the padstack of type "name" and log there location in padstack.log. When you view the log file just click the xy coord and Allegro/APD will zoom center to those coord.
    Oops, see code below.
  • aCraig
    Here's some code that will find all the padstacks of type "name" and log there location in padstack.log. When you view the log file just click the xy coord and Allegro/APD will zoom center to those coord.
    defun(CAL_findPadstack (name)
      let((port userData vias (inc 0))
        port = axlDMOpenFile("ALLEGRO_LOG" "padstack" "w")
        axlLogHeader(port name)
        userData = axlUIGetUserData()
        putprop(userData axlVisibleGet() 'visibility)
        putprop(userData axlGetFindFilter(nil) 'FFEnabled)
        putprop(userData axlGetFindFilter(t) 'FFOnButtons)
        axlVisibleDesign(nil)
        axlVisibleLayer("VIA CLASS" t)
        axlClearSelSet()
        axlSetFindFilter(?enabled 'vias ?onButtons 'vias)
        axlAddSelectAll()
        vias = axlGetSelSet()
        ;axlMsgPut("Vias %L" length(vias))
        foreach(via vias
          when(via->name == name
            inc++
            fprintf(port "Net %L @ %L\n" via->net->name via->xy)
        axlMsgPut("Name %L %L" name inc)
        axlVisibleSet(userData->visibility)
        axlSetFindFilter(?enabled userData->FFEnabled,
          ?onButtons userData->FFOnButtons)
        axlCloseFindFilter()
        remprop(userData 'visibility)
        remprop(userData 'FFEnabled)
        remprop(userData 'FFOnButtons)
        axlClearSelSet()
        drain(port)
        close(port)
  • EvanShultz
    EvanShultz over 17 years ago
     Hi ahmetozsoy,
    You may also find an Allegro SKILL program on SourceLink called hps.il useful. It will display a form that lists all padstacks (including vias) and drill by their name. If you click on a padstack or drill name, all instance will be highlighted and the total number of instances is displayed at the bottom of the form. Perhaps not quite what you're looking for, but I think it's worth mentioning.
  • ahmetozsoy
    Hi
    I have just tried the two ways of finding a via and the two of the solutions work great.
    Thank you very much for your helps.
    Best regards
    Ahmet OZSOY
