  3. How to restore the ministatus content?
  • Views 6722
grom59
grom59 over 17 years ago
Hello. I use ministatus form for my function. Please, tell me how to restore the Ministatus content (Control panel, Options tab) to the default values (TEXT "Active Class and Subclass" and two ENUMs) when function is finished?
  • aCraig
    aCraig over 17 years ago
    Check this thread.
    /forums/p/12715/18504.aspx#18504
    -craig
  • grom59
    Thank you, but that's not exactly what I mean. I load form to "Options" tab (Control Panel) with axlMiniStatusLoad function and when my program is finished a can't restore default view of "Options" tab. I execute axlCancelEnterFun and axlFormClose, but my form (its controls) is still there. Sorry for my English, if I made errors :)
  • fxffxf
    fxffxf over 17 years ago
     If you load your own controls into the options panel then you must do the following for it to work correctly with the rest of Allegro.
    1) register your command as interactive via axlCmdRegister
    2) your code must not return control to the Allegro main processsing loop. This is done by processing user events via one of the axl Select APIs.
    Even if you don't follow these rules Allegro will still switch the option panel to a command specific option panel when you invoke the next command from the allegro menus.
  • grom59
     Thank you, I think now I understand concept of user made commands.
