  3. concept SKILL and pin database objects
  • Views 13925
kerchunk
kerchunk over 17 years ago
 Concept SKILL documentation lists numerous functions for manipulating wire, arc, note and component objects.
The documentation also references the existance of a component PIN object type, as used as an argument to cnGetCompPinName.
There doesn't seem to be functions like
             l_comp_pin_objs   <- cnGetCompPins( comp_obj)
                             and
             l_prop_objs  <-  cnGetPinProps( comp_pin_obj)
available.
So how do you get a list of component pin objects from a given component object? And then a list of property objects from a given pin object?
TIA,
Chris Walters
local Cadence guru
Concept n00b
