  3. How to generate Gerber data of bonding wires using APD 16...
  • Views 15101
How to generate Gerber data of bonding wires using APD 16.2
Alice 2009
Alice 2009 over 17 years ago
 Is anyone know how to generate gerber data of bonding wires in APD16.2? Pls advise.
Alice
  • BillAcito
    BillAcito over 17 years ago
    I assume you don't mean in SKILL, but in general.
    Unfortunately, there are no "easy" options. The primary vehicle for wire output when we moved from layer-based wires to curve based wires is DXF (the wire profiles/curves can be mapped to DXF layers). DXF is the defacto standard for wire bond reports and bonding diagrams. However, that doesn't help your problem. So, ...
    • You can DXF out, then DXF the wires back in on another layer that can be Gerbered out.
    • With the help of the folks in this forum, add a simple skill command that will allow the user to copy the bond wires (based on some filters) to a drawing layer. Then export that to the Gerber file.
    In the mean time, I'll see what I can do to provide it as a native capability in a future release.
    Bill
  • Alice 2009
    Hi Bill,
    Thanks for the reply. I agree with you with both hands to have SKILL to do the copy bond wires job.  However, I have not much knowledge on the SKILL, so i would like to ask for help if anyone can do me a favour.
    In this case, my post is in the right forum, I need SKILL =P
    Thanks in advance =)
