  3. control on Artwork general parameters
  • Replies 8
  • Subscribers 160
  • Views 16350
Nagaraj Shanmu
Nagaraj Shanmu over 16 years ago
I am able to create the artwork films using axlDBCreateFilmRec, How to get control on artwork general parameter settings?
I want to change the 'Device type' 'Error action' 'output units' etc
I didn't find any axl command for this.
Nagaraj.
  • Ejlersen
    Ejlersen over 16 years ago
    Hi Nagaraj
    You can do it by writing a script file and replaying that script. Both the script and the replay can be performed inside a script program.
    Best regards
    Ole
  • Nagaraj Shanmu
    Thanks Ole,
    I can use script and call using axlshell command but I am looking for how can be done with SKILL code
    or
    is there any global userpeference variable to point the art_param.txt file to be used for all designs(and all users)?
    ~Nagaraj.
  • eDave
    eDave over 16 years ago
    There are two ways of doing this. I prefer Ole's method - and I have a stand alone Skill function to do this (attached). The second, and possbly easier, method is to write the art_param.txt file directly. The hard part here will be determining the names of the parameters in the file. Regards, Dave
    setArtworkGeneralParameters.zip
  • Nagaraj Shanmu
     Thanks Ole & eDave!!
  • seyerfred
    seyerfred over 12 years ago
    Hi Dave,
    i try to run your skill setArtworkGeneralParameters but it won't works, here is the error appear "E- Can't find window; form.film_control"
    Please help..thank you
