  3. Zoom in skill code
  • Views 14996
Zoom in skill code
Tolstoy
Tolstoy over 16 years ago
Hello to all the Skill Gurus,
 I'm in need of a skill code that will do the following:
1. Run the Dangling CLines report.
2. Pick the x-y coordinates from the report then..
3. Will open the layer where the dangline was generated/is at then...
4. Will zoom in to the dangline.
 I'm not too familiar with the coding part so I don't know which command to usebut if you can point me to one that might help.
Thanks and much appreciated,
T
  • vramanan
    vramanan over 16 years ago
     Hi Tolstoy
    the good news is Cadence has already done all the coding :-)
    Just do the following
     Tools->Quick Reports->Dangling Lines Report
    Voila now just click on the x and y co-ordinates to view each of the dangling lines
    regards
  • Tolstoy
    Thanks vramanan,
      Is there a way to set it up so that it (the cline) will open just the layer it's on? Currently, I have to manually open the routing layer then select the x-y coordinates. One less step to do if it can be done.
    T
