  3. How to verify if surface mount pad contains solder past...
  • Replies 7
  • Subscribers 163
  • Views 17374
How to verify if surface mount pad contains solder paste
DE202408202727
DE202408202727 over 16 years ago
The attached code checks that a paste pad is present on all smd non-mechanical pins.
pastePadMissingChk.zip
  • DE202408202727
    See attached although I don't see a good reason to make the soldermask pad different to the etch pad there days.
    Dave
  • Mstrghettorigg
    Mstrghettorigg over 16 years ago
    Hello eDave, Thank you for the updated file. It works great! As for the solder mask being larger than the etch pad, it's still in our standard. I think it's just for precaution for when we are forced to use cheaper fab houses. Thank you again for your help!
