  3. ASK for LET Syntax(in Skill)
  • Views 7177
luanvn81
luanvn81 over 16 years ago
Hi everyone !
I’m trying to find out about commands that’s used for skillcode  writing. And I don’t understand “LET“command , who can explain this command for me ?
This is the Example( But I don’t understand anything)
Ex1:
x = 5
let( ((x '(a b c)) y)
println( y ) ; Prints nil.
x)
=> (a b c) ; Returns the value of x.
Ex2:
procedure( test( x y )
let( ((x 6) (z "return string"))
if( (equal x y)
then z
else nil)))
test( 8 6 ) ; Call function test.
ð      "return string" ; z is returned because 6 == 6.
(And this is about LET command)
let - SKILL mode
let(
l_bindings
g_expr1 ...
=> g_result
Description
Provides a faster alternative to prog for binding local variables only. This is a syntax form.
l_bindings is either a list of variables or a list of the form(s_variable g_value). The
bindings list is followed by one or more forms to be evaluated. The result of the let form is
the value of the last g_expr.
let is preferable to prog in all circumstances where a single exit point is acceptable, and
where the go and label constructs are not required.
Arguments
l_bindings Local variable bindings, can either be bound to a value or nil
(the default).
g_expr1 Any number of expressions.
Value Returned
ð     g_result The result of the last expression evaluated
  • DE202408202727
    DE202408202727 over 16 years ago
    Let delcares local variables within the scope included within its brackets. By default they are set to nil but you can assign a value as you have shown in your examples.
    While learning Skill I suggest that you do not assign values within the let statement.
    Your example 2 is, therefore, better written:
     let( (z)
      z = "return string"
      if( (equal x y)
       then z
       else nil
    Note that x is not included in the let statement variables because it has already been declared in the procedure variables.
  • luanvn81
     Hi!
    Thanks for your answer. Now i want to practice Skill writting but I dont' know which program I can write skill function. Can you show me?
    Thanks.
    Luan
  • tltoth
    tltoth over 16 years ago
    If you don't have SKILL license you are not allowed to load a skill function from console. But there is a workaround made by r2d2b9 that can be found on skill_school of yahoo group. The trick is that pcbeditor runs skill commands at startup from allegro.ilinit file usually placed in pcbenv directory.
    put this code in allegro.ilinit
    ; **** code to load files in Design L ****
    axlCmdRegister( "skload" `skload ?cmdType "interactive"
    procedure( skload(arg1)
    load( arg1 )
    );end skload
    ; **** end code ****
    It registers a command "skload" by which you can load your il files.
    The syntax is :   skload filename.il
    However you won't have debugging capabilities only the error messages from console.
