  3. Problem in Allegro PCB Editor
  • Views 17884
Neha Anu
Neha Anu over 16 years ago
Hi all,
I'm new to the Allegro PCB Editor Tool.Actually when i tried to Click on Route->Route Editor or Route->Route Automatic,an error
"Program has encountered a problem and must exit.The database will be saved(if applicable)."
Can anyone pls give me solution to this?Why does this error occur?
Thnks,
Neha
  • oldmouldy
    oldmouldy over 16 years ago
    Which version of PCB Editor?
    Could be a corrupt database, try Tools>Database Check within the tool, check both boxes and "Check", or run the DB Doctor off line from the PCB Editor Utilities Group.
    Will the Router data export? File>Export>PCB Router
    Spaces in the board file name or path? Spaces in the board file name are always likely to cause an issue, later versions have fewer issues with spaces in the path.
    Get the latest available hotfix / ISR for the version that you are using.
  • Neha Anu
    Thanku for ur support.It really works fine.
    Thanx
    Neha.
