  3. How to run skill program using 3rd party application(vb...
  • Views 2740
How to run skill program using 3rd party application(vb.net,c++)
Dref
Dref over 16 years ago
Im creating a new application w/c will no longer requires opening allegro manually.
Planning to automate some of the checking done using 3rd party application probobly
developed in (vb.net or c++). Using "extracta" alone will be very tasky that's why i would
like to seek help if anyone already have developed an application that can run SKILL program
without manually opening ALLEGRO anymore. Most probobly it will run hidden so user dont
need to see allegro opening anymore.
Thanks for yo help!
  • Charlie Davies
    Charlie Davies over 16 years ago
    The Skill interpreter can only be run in an Allegro session.  You can launch Allegro with the -nographic switch to have it run without a GUI.  A X display buffer is required even when using the -nographic option.
  • Dref
     Hi Charlie,
    Thanks a lot. Still looking at your suggestions.
    BTW, if you have a sample program can i have a copy.
    Thanks in advance!
  • redwire
    redwire over 16 years ago
     IIRC you need to have another command line switch which executes a script which calls the SKILL code... perhaps there is a way to "autostart" a SKILL routine with a script?  Never done it without a script. :)
  • DE202408202727
    DE202408202727 over 16 years ago
    These are the steps:
    Register a command to execute your Skill code in your Allegro.ilinit file. (e.g . axlCmdRegister("mySkill" 'mySkillStart)
    Either load or autoload that code in your Allegro.ilinit file. (e.g. mySkillStart.autoload = "mySkill.il")
    Create your script to call the Skill command (e.g. mySkillScript.scr)
    Run the script (e.g. "allegro -s mySkillScript -product PCB_Designer -nographic myDesign.brd")
