  3. skill code to delete existing films
  • Replies 7
  • Views 18962
Pieman
Pieman over 16 years ago
Does anyone have a skill code that will delete existing films?
 I have code to create my films from a GUI, but only on a new board file (only top and bottom to start with).
 I need to be able to delete existing films then add my new films, otherwise I get my new films and the old ones still exist.
 Thanks for any help.
 Marvin
I can be contacted directly at:
mlaw@cardaccess-inc.com
  • DE202408202727
    DE202408202727 over 16 years ago
    Hi Marvin,
    Try:
    axlDeleteObject(mapcar(lambda((film), axlGetParam(strcat("artwork:", film))), setof(film, axlGetParam("artwork") ->groupMembers, film != "TOP")))
    Dave
  • Pieman
     Dave,
    Thank you for such a quick response.  I now will admit my stupidity by stating that I partcially understand this bit of code, but not fully.
     I have been searching for the documentation in Allegro to understand the AXL commands but as of yet have not located it.
    Can you direct me as to the possible location in the Allegro directory structure as to where these might be, or give a breif description as to how this code works?
    Also, if I were to implement this in a test skill file, would I call this by way of something like:
    axlCmdRegister ( "flmdel" 'film_delete )
    then copy your code here
     Thanks again.
    Marvin
  • DE202408202727
    Hi Marvin,
    The code needs to be wrapped in a funcion for it to be called that way:
    defun( filmdel () axlDeleteObject(mapcar(lambda((film), axlGetParam(strcat("artwork:", film))), setof(film, axlGetParam("artwork") ->groupMembers, film != "TOP"))))
    Place this and your axlCmdRegister line in your Allegro.ilinit file.
    The documentation is in:
    C:\Cadence\SPB_16.x\doc\algroskill\algroskill.pdf and C:\Cadence\SPB_16.x\doc\sklangref\sklangref.pdf
    I refernce the functions in:
    C:\Cadence\SPB_16.x\share\pcb\examples\skill\DOC\FUNCS
     Dave
  • Pieman
     Dave,
    You have been a great help.
    By the way, do you know a Bobby Mosley?
    I worked with him at Tektronix.
    Marvin.
  • DE202408202727
    Hi Marvin,
    Yes. Bobby worked here for a few months. He's one of the good guys!
    Dave
