  3. removing backslashes
  • Replies 7
  • Views 18943
Ejlersen
Ejlersen over 16 years ago
Hi
Anyone having any idea how I can replace double backslash characters in a string with single backslash characters?
 Example "\\\\NS2009\\hp color LaserJet 2550 PS" replaced to "\\NS2009\hp color LaserJet 2550 PS"
Best regards
Ole
  • fxffxf
    fxffxf over 16 years ago
     In Skill, just as in C/C++ a backslash character (\) in a string is treated as the start of an escape sequence. For example, if you want to embed a double quote (") in a string you need to escape it:
       a = "Show me a double quote ( \" )"
    Some escape characters are special such as newline ( \n ), tab ( \t) etc.
    To get a double quote to appear you must escape it with another backslash -- ( \\ ). For UNC paths this can look somewhat odd since you might see in Skill for a UNC path - ( "\\\\server\\c\\tmp" )
    Now on UNIX, you rarely encounter a backslash character in strings unless it doing its job of escaping a non-backslash character. But due to the DOS use of the backslash as a directory seperator you see it a lot more on Windows. Fortunately modern Windows APIs will almost always accept the UNIX style directory slash character ex. "//server/c/tmp" will work just as well as "\\\\server\\c\\tmp"
    If you have a directory or UNC path string you can use axlOSSlash to convert DOS backslash directory seperators to UNIX style.
  • Ejlersen
    Hi Dave
    The funny thing here is that I get an error running rexCompile("\\") without running RexMagic(nil) first.
    So, some kind of magic must be happening, even for rexCompile :-)
    The problem I'm facing is that its a printer name I wan't to pass on to a form and a script to be replayed. I don't know what will happen if I try to adress a printer with forward slash instead of backslash - but I could try. For paths I've always used forward slashes and they work fine - so maybe it will work for printer driver also?
    Best regards
    Ole
