  3. removing backslashes
  • Replies 7
  • Views 18942
Ejlersen
Ejlersen over 16 years ago
Hi
Anyone having any idea how I can replace double backslash characters in a string with single backslash characters?
 Example "\\\\NS2009\\hp color LaserJet 2550 PS" replaced to "\\NS2009\hp color LaserJet 2550 PS"
Best regards
Ole
  • aCraig
    aCraig over 16 years ago
    Ole,
    Have you tried using rexSubstitute or rexReplace?
    -Craig
  • Ejlersen
    Hi Craig
    Yes, I've tried it together with rexMagix(nil) and without - but it may be my RexCompile string that is wrong.
    I used the following lines (from memory since I'm at home now, so there may be a slight difference in real life :-))
    rexMagic("nil")
    rexCompile("\\")
    rexReplace("\\\\ns2009\\HP LaserJet 2550 PS" "\\" 0)
    - If I substitute \\ with \ in the above line I get an error message
    rexMagic(t)
    Best regards
    Ole
  • DE202408202727
    DE202408202727 over 16 years ago
    Don't be fooled by double back slashes:
    strlen("\\\\") => 2 (not 4)
    But what you probably want to do is:
    rexCompile("\\\\")
    rexReplace(str, "/", 0)
    To return "//NS2009/hp color LaserJet 2550 PS"
    Dave
  • aCraig
    Yes, but rexMagic(nil) should turn off the special interpretation of the meta-character "\"
    rexMagic(nil)
    rexCompile("\\") ; should be a string length fo 2 to rexXXX
    rexReplace("\\\\ns2009\\HP Color LaserJet" "\" 0);  errors due to 2nd argument I believe
    rexCompile("\\\\")
    rexReplace("\\\\ns2009\\HP Color LaserJet" "\\" 0);  => "\\ns2009\\HP Color LaserJet"
    So I guess I'm confused as to how rexMagic() really work or there's a bug.
  • DE202408202727
    And there's the confusion. rexMagic won't affect the string you pass to rexCompile. Whatever the state of rexMagic you will be passing one character to rexCompile with rexCompile("\\"). RexMagic doesn't affect Skill code - only the rex commands.
