  3. axlReplacePadstack axlReplacePadstack
  • Views 15830
Schendly
Schendly over 16 years ago
 I am trying to learn SKILL and I am going through 'allegroskill.pdf' manual and I can't get the axlReplacePadstack on  page 245 to work.  It says: "The padstack can be referenced by name or a dbid and must be present in the Allegro PCB Editor database"
I tried both dbid and padstack name I am still getting nil. I know how to do it with the Allegro Editor command.
Thanks for any help.
Schendly
Version Allegro Xl 16.01
  • Ejlersen
    Ejlersen over 16 years ago
    Hi Schendly
    axlReplacePadstack(o_dbid/lo_dbid o_padstackdbid/t_padname)
    o_dbid/lo_dbid is either single or list of ids
    o_padstackdbid/t_padname can be dbid or padstack name
    Although this seems pretty obvious I've not been able to get it to work either. I'm on 16.3. I'll file an SR to see whats going on here.
    Best regards
    Ole
  • Schendly
    Thanks, Ole.
    As I am a novice in Skill, I thougth I was misreading the manual.
    Regrads,
    Schendly
  • DE202408202727
    DE202408202727 over 16 years ago
    Try this function. It works in 16.3: defun( AFn_replacePads () let((pins, padstackNames, n, padstack, psid) axlClearSelSet() axlSetFindFilter(?enabled '("NOALL", "PINS"), ?onButtons '("PINS")) axlSelect(?prompt "Select pins") pins = axlGetSelSet() padstackNames = unique(pins ~>name) when(length(padstackNames) > 1 n = axlUIMultipleChoice("Select the padstack name of the pins to replace", padstackNames, "Select pins to replace") pins = and(n >= 0, setof(p, pins, p ->name == nth(n, padstackNames))) ) axlHighlightObject(pins) and( pins padstack = car(axlUIDataBrowse('PADSTACK '(RETRIEVE_NAME, EXAMINE_DATABASE), "New Padstack Name", t)) psid = axlLoadPadstack(padstack) axlReplacePadstack(pins, psid) ) axlDehighlightObject(pins) axlClearSelSet() axlFinishEnterFun() ))
  • Ejlersen
    Hi
    Found the issue, you need to load the padstack before it can be used to replace. Code below works fine, so Dave, thanks for the hint in your code with axlLoadPadstack - that did the trick.
    axlClearSelSet()
    axlSetFindFilter(?enabled list("noall", "vias", "invisible"), ?onButtons list("noall", "vias"))
    axlAddSelectAll()
    selSet = axlGetSelSet()
    axlClearSelSet()
    pad = axlLoadPadstack("via019")
    via = axlReplacePadstack(selSet, pad)
    Best regards
    Ole
  • Schendly
    Thanks, Dave and Ole.
     I will try it.
    Schendly
