  3. skill to zoom in and out only with mouse
  • Subscribers 168
  • Views 19699
AbouYahya
AbouYahya over 16 years ago
hi
Can anyone help me
i need a skill to zoom in and out only with mouse
i work with 15.7
merci.
  • vramanan
    vramanan over 16 years ago
     Hi
    You could implement this by adding the following  on the env file
    The env file is located in
    %CDSROOT%/share/pcb/text/env
    ########Start Cut Here
    # MOUSE WHEEL SUPPORT (Windows only)
    #   Environment Variables - Note quote variables so they are evaluated
    #        at button time not when this file is read.
    #   - _wheelcnt variable is set based upon number of detents wheel moved
    #    range is -4 to 4 (no 0)
    #   - sx1 and sy1 are cursor coordinates when wheel is moved
    # Button values
    #   wheel_up:   when wheel is moved up
    #   wheel_down: when wheel is moved down
    #   wheel:    up/down if either of above 2 buttons are not assigned
    # Keyboard modifiers (note we are case insensitive)
    #   S - shift key
    #   C - control key
    #   SC - shift and control
    #     Example: SCwheel - for wheel button assignment with both shift & control keys
    # Button factor may be factorion (e.g. 0.5)
    set buttonfactor = 1
    button wheel_up "zoom in $buttonfactor"
    button wheel_down "zoom out $buttonfactor"
    button Cwheel_up "zoom in $buttonfactor"
    button Cwheel_down "zoom out $buttonfactor"
    ########End Cut Here
    Regards
    Venkata
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
     Those commands could also be executed inside skill using AxlShell.
    Best regards
    Ole
  • AbouYahya
    hi
    can you give me a detail pleaz
  • fxffxf
    fxffxf over 16 years ago
     This requires Allegro 16.0 or newer. It is not available in 15.7
  • tomoo
    tomoo over 16 years ago
    I believe that you can zoom in and out by using middle(wheel) mouse without skill in 15.7 default configuration .
    Usually I also use the function without anything particular setting in 15.7.
    Please refer to the following description in the 15.7 product document.
    Middle Mouse Button
    Press and hold the middle mouse button while moving the mouse in the direction you want to pan and use the view (zoom) features (see Viewing a Design). If you click the middle mouse button, the system either zooms in or out, based on the direction in which you move the cursor. If you move from top left to bottom right, the display zooms out. If you move from bottom right to top left, the display zooms in. In both cases, a rectangle that depicts the new zoom area displays. You can disable the zoom functionality by setting the environment variable no_dynamic_zoom.
    In Windows, for Wheel mouse devices (middle mouse button is a wheel), the middle mouse button must be defined so that the roam function works correctly. Access the Control Panel to open the Mouse Option Control and check the behavior.
    The easiest way to zoom in, zoom out, and move across a design display in the UI workspace is by way of the middle mouse button. The button gives you access to all the zoom features available from the menu bar or keyboard commands (except zoom in, which is integrated into zoom points) without the need to make a menu selection or enter a command at the console window prompt. Use of the middle mouse button also enables you to roam or pan across a design.
    The zoom function remains active until you click the middle mouse button a second time. (Clicking the left mouse button also takes you out of zoom mode.)
    If you prefer not to use the dynamic zoom features, you can disable the functionality by setting the environment variable no_dynamic_zoom in the User Preferences Editor. By setting this variable, middle-button functionality is limited to zooming in or zooming out.
    Hope this helps.
    Tomo
