  3. how to remove a subclass
  • Replies 10
  • Subscribers 162
  • Views 19942
Ejlersen
Ejlersen over 15 years ago
Hi
I've been looking all over for an axl function to delete a subclass - but I've not been able to find such a function.
Can anyone help me?
Best regards
Ole
  • fxffxf
    fxffxf over 15 years ago
     axlDeleteObject - assumes layer is empty and not a pre-defined Allegro subclass (e.g. can't delete ETCH/TOP)
    Example if you want to delete a user subclass named "FOO" on board geometry
     p = axlLayerGet("BOARD GEOMETRY/FOO")
    axlDeleteObject(p)
  • Ejlersen
    Hi
    Thanks that just what I needed
    Best regards
    OIe
  • EvanShultz
    EvanShultz over 15 years ago
     What if I want to delete BOARD GEOMETRY/BOTH_ROOMS or MANUFACTURING/NO_PROBE_TOP since those subclasses are unused? I'd like to eliminate unneeded layers to clean up the DB, instead of having "wasted" layers in my company's otherwise streamlined and customized default boards. There's really no way to eliminate pre-defined subclasses?
  • EvanShultz
     To anyone else looking for confirmation, the answer is no. Pre-defined subclasses are there to stay, an AE tells me.
  • VijayVela
    VijayVela over 12 years ago
    I'm trying to find out a method of removing all un-used subclasses (not the predefined subclasses).
    How do we iterate through all the custom subclasses and how do we find out if its is empty or not?
    Thanks.
    Vijay Anandh Vela, CID
