  3. Where is that property ?
  • Views 14820
Romme
Romme over 16 years ago
Hello dear friends.
  Im having a problem with someproperties in footprints created by some colleagues loooong time ago.
  In the footprint there was created a property called Revision as string containing the date of creation. Now we have done a mayor cleanup and entered footrpints in a database with Revision as integer fourthrunning numbered. As string and integer is much different :-), we cannot load netlist into boards with old symbols.
  To solve the problem we need to do a skill that runs through the footprint library and "testing" all footprints for a property called Revision, and copy these files to a sub folder.
  Copying files and walking through the directory is not a problem, the problem is to find a property that i do not know where is attached.
  any clues anyone ?
Sincerely
  Klavs Rommedahl.
  • Ejlersen
    Ejlersen over 16 years ago
    Hi Klavs
    I would say that if you open a .dra file and run x=axlDBGetDesign() then x->prop->?? should show you revision if it exists.
    If not, please send me a sample .dra file and I'll see what I can do.
    Best regards
    Ole
  • RFDTeradyne
    RFDTeradyne over 16 years ago
     Klavs,
    If the problem is a type mismatch of the property between the old and new symbols, you should be able to retain the type as "string" in the new ones. You will see a integer represented as characters. Unless you are doing math, this should be OK.
    You can use extracta instead of skill.  The control file looks like:
    BOARD
    REVISION (or whatever your property name is)
    END
  • Romme
    Many thanks to both. I'm embarrassed as i actually got this working for some time ago, had a winter holliday and forgot everything :-).
    Maybe not the most beautyful or perfect solution, but it works...
        axlVisibleDesign(t)
        axlUIWRedraw(nil)
        prp = axlDBGetPropDictEntry("Revision")
        if( (prp != nil)
          if( (prp->dataType == "STRING")
            fprintf(oufi "%d \t %s \n", ++j, f_full)
      J is a counter to see how many with this property.
    Sincerely
      Klavs Rommedahl.
