  3. default-mil.dlt
  • Subscribers 167
  • Views 17280
default-mil.dlt
Pieman
Pieman over 16 years ago
Coding Associates,
I am trying to determine how the size values of drills are obtained for the .dlt (drill chart) program, especially those for oval slots.
 If there is a document that discribes this, pleae point me in that direction.  If you have an answer, that would be appreciated also.
Also, is there documentation that would identify what system names are defined for the ?ColumnDefinitions?
 The obvious ones are: Figure, Holesize, Tolerance Quantity.  I would like to find out what others already exist, so I don't have to re-create the wheel with custom 'User' definiitons.
 Thank you,
Marvin.
  • DE202408202727
    DE202408202727 over 16 years ago
    To get the drill size values you will need to use extracta to obtain the DRILL_HOLE_NAME and DRILL_HOLE_NAME2 values.
    The documentation for the dlt files is in the sample dlt files in ...\share\pcb\text\nclegend
    Dave
  • bojo2112jon
    bojo2112jon over 5 years ago
    Nice to see you! USA is one of the most brilliant places in the whole world. But I know that learning is more important than travelling in any case. So, I mostly write my paper for free and by my own, but there were few more times when I had to order it from professionals from this writing agency and I should say that I was completely pleased by the results of their assignments and I would like to propose for every learner to use their helpful online services.
