  3. What are commands like: _DTL_UTLIS_get_temp
  • Views 940
Pieman
Pieman over 16 years ago
I came across a skill program (DT_rotator.il) that is used to rotate silkscreen.
Within this program is the following line of code:
 (unless (setq TempDir (_DTL_UTILS_get_temp))
When I run the program, I am getting the following error message:
 *Error* toplevel: undefined variable - _DTL_UTILS_get_temp
 Can someone please explain what these '_********' commands / variables are?
 Thank you,
Marvin Law
  • DE202408202727
    DE202408202727 over 16 years ago
    It is calling a function that is probably loaded from another file. Look for a file named "DTL_UTILS.il" or similar and load that before running the rotator code.
    Dave
