  3. Create manufacturing data
  • Replies 12
  • Subscribers 166
  • Views 21746
philE
philE over 16 years ago
I am trying to write a skill program that will create all of the files required when a layout is completed and ready to go to fab or assembly.  I just want to issue a command like “CreateMFG” and have it create:
1.       Gerber artworks
2.       Drill data
3.       Fabrication PDF
4.       Assembly PDF
5.       Pick and Place info
6.       ODBC++ info
Does anybody have anything like this that I could use as a starting point?  Writing a skill program to create a pdf of the drawings is the one I really need an example of.
Thanks, Phil
  • Ejlersen
    Ejlersen over 16 years ago
    Hi Dave
    How can this be done? Where do you find a free Acrobat distiller?
    I'm currently trying to enhance my pdf skill program to support ghostview for compiling ps files into a pdf document. However user will have to install a postscript printer driver, does ghostscript give you that?
    Best regards
    Ole
  • DE202408202727
    DE202408202727 over 16 years ago
    Hi Ole,
    Google Adobe Acrobat Distiller and download it.
    When installing, choose the local printer option and set the file to Local Port. Don't select the "generic post script printer", instead browse to your distiller location.
    You will also need Ghostscript.
    Dave
  • Ejlersen
    Hi Dave
    Will this give me anything that I don't get by just installing a standard laserprinter ps driver and using ghostview to compile and collect the ps files into a pdf document?
    Ole
  • DE202408202727
    Hi Ole,
    Probably. It does give you a simple one-button method of producing the pdf files as Phil required - by using command line calls.
    I have a small utility that does a screen grab and emails all in one go. Trivial to do with the distiller method.
    Dave
  • Ejlersen
    Hi Dave
    Thanks for your advice, I've been looking for an Adobe Distiller download link without any luck, do you have one?
    As far as I can see its a pay option from Adobe, did I not look in the correct place?
    Best regards
    Ole
