  3. Create manufacturing data
  • Replies 12
  • Subscribers 166
  • Views 21745
philE
philE over 16 years ago
I am trying to write a skill program that will create all of the files required when a layout is completed and ready to go to fab or assembly.  I just want to issue a command like “CreateMFG” and have it create:
1.       Gerber artworks
2.       Drill data
3.       Fabrication PDF
4.       Assembly PDF
5.       Pick and Place info
6.       ODBC++ info
Does anybody have anything like this that I could use as a starting point?  Writing a skill program to create a pdf of the drawings is the one I really need an example of.
Thanks, Phil
  • philE
    OK, how about this instead....can anybody give me an example of skill code which can create a pdf file from a comand line comand.
  • DE202408202727
    DE202408202727 over 16 years ago
    It is possible - but not at all trivial.
    Take a look at Apache FOP (http://xmlgraphics.apache.org/fop/).
    I can give you some more hints if you're prepared to embark on this path.
    At this stage I'm not exactly sure what you are wanting as an answer. Having a one-button output generation utility requires a reasonably intelligent engine. I have done something similar - for outputting ODB++. Here are the the command lines:
    sprintf(cmd, "brd2odb -dgr -a2l -c a -d -jn %s -v14_thermals -s all -sf %s-xu mm -ssfs u -read_sqa no %s\\%s.brd",
        lowerCase(axlCurrentDesign()), if(suppressUnconnectedPads, "-sp ", ""), getWorkingDir(), axlCurrentDesign())
    axlRunBatchDBProgram("brd2odb", cmd, ?noUnload t)
    This is a small subset of the overall utility.
    Cheers, Dave
  • philE
    Thanks for the reply.
    All I want to do is to have a program which turns on 4 layers of the PCB design layout, figure out the extent of the data which is now visible and make a PDF of that data.
    Does my explanation make sense?
    Phil
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    If you have Adobe PDF installed (Acrobat, not reader) then you can use the attached compiled skill program to create pdf files.
    Version 7 and 8 are implemented, if you use version 6 set it to 7 and if you use 9 then set it to 8.
    It basically plots your film setup inside manufacturing.
    There are some glitches - no spaces allowed in directory and board file names.
    After loading the skill program, use "ns_pdf" to run.
    Best regards
    Ole
    ns_pdf.zip
  • DE202408202727
    Hi Phil,
    This can be achieved relatively easily (and freely) by using ghostscript and a free Acrobat distiller.
    Let us know which way you decide to go.
    Dave
