  3. Can I improve/simplify my regex code for finding certain...
  • Views 2026
Can I improve/simplify my regex code for finding certain symbol names?
EvanShultz
EvanShultz over 16 years ago
I want to look at a comp's symbol for a keyword indicating the symbol is a leadless SMT package like BGA, QFN, etc. I'm using the code:
unique(mapcar(lambda((x) rexMatchp(x comp->package)) list(".BGA." ".DFN." ".QFN."))) == list(nil)
I check the package against a list of keywords using a regex, then I eliminate duplicate elements of the list to return a list of only nil if none of the keywords are found in the symbol (makes it easier to add additional keywords). I'm safe with this because our symbol library has naming rules which guarantee this will work.
This works, but seems overly complicated and requires verbose commenting. Are there better ways to do this? Here were my thoughts:
1. I tried to wrap mapcar(...) inside dptr() but it appears dtpr() doesn't interpret list(nil ... nil), or even list(nil), as an empty list.
2. The regex engine of Allegro SKILL doesn't seem to support advaned regex features I'm used to with other languages, such as pipe symbols. rexMatchp(".BGA|DFN|QFN." comp->package) always returns nil. Am I correct that advanced regex features, like pipes for alternation, aren't available in Allegro SKILL? It appears IC SKILL might from http://www.cadence.com/forums/p/14771/25538.aspx.
3. I couldn't come up with a solution that didn't use a regex, but it doesn't mean there isn't one.
  • aCraig
    aCraig over 16 years ago
    Hi Evan
    Try this,
     apply('or mapcar(lambda((x) rexMatchp(x comp->package)) list(".BGA." ".DFN." ".QFN.")))
    This will return t if you get a match and nil if you don't.
    -Craig
  • aCraig
    Hi Evan,
    It appears that pcreCompile, pcreExecute are supported in Allegro 16.2 in my case. pcreCompile supports "alternative" patterns like what's in your example. However there seems to be no documentation in the SPB docs. Maybe Andrew in the IC Forum can provide the pdf.
    -Craig
  • EvanShultz
    Genius! Yes indeed, the pcre* functions are present and they work just as the rex* expressions, from what I can tell. But obviously much more powerful. Thanks Craig!
    To test each method, I wrapped them each in a for loop and cranked up the iterations until I reached an execution time which showed some difference between the methods. The method in my first post, as I suspected, isn't so good. Using apply() was 21% faster. Using pcreMatchp was another 19% faster, for a total speedup of 44%. Not the best way to gauge code efficiency, but it's quick and works on Windows.
  • EvanShultz
     FYI, 16.3 for Windows ships with an outdated version of sklangref.pdf. v07.02, the current release, has the pcre* functions and a few other new ones. Even zipped the PDF is more than 750kB, so I can't attach it here.
