  3. Zoom scrolling & worksheet environment script problem
  • Views 1853
archive over 16 years ago
Firstly, I am new to allegro and I am not a scripter.
I am using script mentioned below for scrolling worksheet up & down by mouse wheel, but I am facing the problem for vertical scrolling as it stops between the design & dosent allow to scroll downwards. Horizantal scrolling works perfectly.
# use scroll button on mouse to scroll vertically
button  wheel_up  "roam y -$roamInc"
button  wheel_down  "roam y $roamInc"
# use shift + scroll button on mouse to scroll horizontally
button  Swheel_up  "roam x -$roamInc"
button  Swheel_down "roam x $roamInc"
Also I can access my worksheet only upto (-128, 161) mm in X direction & (71, -128) mm in Y direction.
How can I increase worksheet size?
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    Your scroll functions should work fine, mine are the exact same and have no issues, maybe you need an update to your installation?
    You can change worksheet size in Setup->Design Parameters->Design
    Best regards
    Ole
    Hello Ole, By expanding worksheet size, scrolling function now working fine. Thanks for the reply. Regards, Prasad
