  3. how can you get the current grid settings
  • Replies 7
  • Views 20017
Ejlersen
Ejlersen over 16 years ago
Hi
Is there a way to get the current grid settings? I've looked over the documentation without finding anything, so hopefully someone here knows how to?
Best regards
Ole
  • fxffxf
    fxffxf over 16 years ago
     you can try a recent 16.3 isr and use the axlDBGridGet
      NAME
    axlDBGridGet - get grid values
    SYNOPSIS
    axlDBGridGet(
    nil
    ) ==> lt_grids
    axlDBGridGet(
    t_gridName
    ) ==> og_grid
    FUNCTION
    Returns current grid values. Function has two modes:
    - if gridname is nil returns list of names
    - If given a grid name return its grid characturistics (see below)
    Reserved grid name is "non-etch" otherwise grid names follow Allegro
    ETCH subclass names.
    Use axlDBDisplayControl to control grid color and visibility.
    Grids have the following attributes:
    NAME TYPE DESCRIPTION
    objType string Name of the object - grids
    readOnly nil can modify object
    name string Name of grid
    xOrigin dbrep X origin of grid
    yOrigin dbrep Y origin of grid
    xMajor dbrep Major X spacing of grid (read-only)
    yMajor dbrep Major Y spacing of grid (read-only)
    xGrids l_dbrep Spacings X of grid (always a list of dbreps)
    yGrids l_dbrep Spacings Y of grid (always a list of dbreps)
    NEEDS
    t_gridName -- name of grid or nil to get all grir names
    RETURNS
    lt_gridds -- list of grids
    og_grid -- disembodied property list containing grid settings
    SEE ALSO
    axlDBGridGet
    EXAMPLE
    # get and print all grids
    grids = axlDBGridGet(nil)
    foreach(g grids
    grd = axlDBGridGet(g)
    printf("GRID name=%s values=%L\n", grd->name, grd)
    NAME
    axlDBGridSet - set the design grid
    SYNOPSIS
    axlDBGridSet(
    og_grid
    ) ==> t/nil
    FUNCTION
    This modifies the grid settings in the design.
    In addition to the grid names (see axlDBGridGet), two symbolic
    grid names are available:
    'all - sets all grid values
    'etch - sets all ETCH grid values
    As a convenience when setting a single the xGrids or yGrids attribute,
    you can use a float.
    Both xMajor and yMajor values are automatically determined by the sum
    of the spacings in xGrids and yGrids respectively.
    NOTES
    - Non etch grids may not have multiple spacings. We only use the
    first grid seen.
    - Setting grids is not undo-able (this may change in the future).
    - Etch grids names are the same as ETCH layer names. This may
    change in the future.
    - Origin values must be within drawing extents or 0.
    - If Grid dialog is open it will not be updated if you change the grid
    settings via this API.
    NEEDS
    og_grid - a grid disembodied property list from axlDBGetGrid
    RETURNS
    t if changed grid, nil if failure
    SEE ALSO
    axlDBGridGet, axlDBDisplayControl
    EXAMPLES
    1) Modify TOP grid settings
    grid = axlDBGridGet("TOP")
    grid = axlDBG
    2) Modify all grids ( note allow xGrids and yGrids to NOT be listed)
    grid->name = 'all
    grid->xGrids = 5.0
    grid->yGrids = 5.0
    axlDBGridSet(grid)
    3) Modify all etch grids
    grid->name = 'etch
    grid->xGrids = '(5.0 7.0)
    grid->yGrids = '(5.0 6.0)
    axlDBGridSet(grid)
  • Ejlersen
    Hi
    Thanks for the answer, just what I was looking for.
    Did a dumplist back at isr004 without finding it, so will redo dumplist in newest isr to see if I have it available
    Br
    Ole
  • Ejlersen
    Hi
    I can see 2 more new functions in the newest ISR - axlDBDummyNet and axlDBTextBlockCreate
    Do anyone have a good description of those?
    Best regards
    Ole
  • Ejlersen
    Hi
    I've made a few changes to Uri's original grids.il skill program. Currently I've not changed it to use the GridSet command, but just the GridGet.
    It now shows the value of the current non-etch x-grid and the current top layer xgrid for reference.
    I don't have the ISR number where this functionality was introduced and hence only allow the current grid to be shown if isr009 is installed. Otherwise it will just say that you need to update.
    Have fun
    Best regards
    Ole
    grids.zip
  • fxffxf
        NAME
             axlDBDummyNet - retrieve dummy nets
    FUNCTION
    axlDBDummyNet (
    g_mode
    ) -> lo_dbid/nil
    SYNOPSIS
    This returns all dummy nets in design.
    Two courtesy options are provided which are:
    - 'pin for any dummy net that has a pin return the first pin of the
    dummy net
    - 'shape for any dummy net that has a shape return the first shape of
    the dummy net
    Typically each dummy net in design will only have a single pin
    or shape but this may not always be the case. Clines or vias cannot,
    by themselves exist on a dummy.
    Symbols (dra) do not have dummy nets
    NEEDS
    g_mode: 'pin - return list of 1st pins on dummy nets
    'shape - return list of 1st shapes on dummy nets
    RETURNS
    t - success
    nil - failed due to incorrect arguments
    SEE ALSO
    axlIsDummyNet, axlDbidName
    EXAMPLES
    1) Print all 1st pins on dummy nets
    foreach( mapc x axlDBDummyNet('pin) printf("%s\n" axlDbidName(x)))
    2) Get all dummy nets on design
    p = axlDBDummyNet(nil)
    NAME
    axlDBTextBlockCreate - create a new text block
    SYNOPSIS
    axlDBTextBlockCreate(
    x_blockTemplate
    ?width f_width
    ?height f_height
    ?lineSpace f_lineSpace
    ?charSpace f_charSpace
    ?photoWidth f_photoWidth
    ) => x_textBlock/nil
    FUNCTION
    Creates a new block block from the template block number provided.
    By providing optional textblock charactistics
    You can get available text blocks by:
    lst = axlGetParam("paramTextBlock")
    NEEDS
    x_blockTemplate
    f_XXX values
    RETURNS
    x_textBlock - new text block
    nil - failed, Typically your exhausted the number block Allegro provides
    or one of the parameters is not the correct data type.
    SEE ALSO
    axlGetParam, axlSetParam, axlDBTextBlockCompact
    EXAMPLES
    - create a new text block based upon text block 1 but change width and height
    blockNum = axlDBTextBlockCreate(1 ?width 15.0 ?height 16.0
