  3. How to set Referenced Cset of a NetClass by skill (allegro16...
  • Views 15353
How to set Referenced Cset of a NetClass by skill (allegro16.3)
stillfish
stillfish over 16 years ago
I follow the document's description of axlNetClassCreate() function :
blah blah.........Netclasses can be constrainted by assigning csets
via the PHYSICAL_CONSTRAINT_SET
SPACING_CONSTRAINT_SET or
ELECTRICAL_CONSTRAINT_SET. Same Net constraints shares the same domain with the
SPACING_CONSTRAINT_SET.
And I use axlDBAddProp with SPACING_CONSTRAINT_SET to add property of a NetClass.
But when i open constraint manager , the NetClass does not change its referenced spacing C set.
Is there any method to set the reference Cset by skill?
  • Ejlersen
    Ejlersen over 16 years ago
    Hi
    To my knowledge this can only be accomplished using scripts. I've done this with success using the following procedure and procedure call. Procedure creates Netclass in domains and assigns csets.
    ns_map_cset2netclass(spacingCset recordid physicalCset)
     ; --------  arg1 = spacing Cset name, arg2 = Netclassname, arg3 = Physical Cset name
    procedure( ns_map_cset2netclass( arg1 arg2 arg3)
    let((nc_domains)
      nc_domains = '(spacing physical)
      axlNetClassCreate(arg2 nc_domains)
      fprintf(tmp_file "cm startTransaction ( Design \"%s\" ) ( \"Net Class\" \"%s\" ) TS_DEFER\n" axlCurrentDesign() arg2)
      fprintf(tmp_file "cm add ( \"Net Class\" \"%s\" ) to ( \"Spacing CSet\" \"%s\" )\n" arg2 arg1)
      fprintf(tmp_file "cm commitTransaction ( Design \"%s\" ) ( \"Net Class\" \"%s\" ) TS_DEFER\n" axlCurrentDesign() arg2)
      fprintf(tmp_file "cm add ( \"Net Class\" \"%s\" ) to ( \"Physical CSet\" \"%s\" )\n" arg2 arg3)
    ); end procedure
    Best regards
    Ole
  • stillfish
    Thanks for your reply,  it is helpful for me to finish my tasks.
