  3. Looping folders fail after x numbers of entries ???
  • Views 14224
Romme
Romme over 16 years ago
Hello dear Friends.
  We have some skill tools that change properties on footprints and other files. We can do this perfectly on 1 file, 10 files and so on up. But it fails and kills Allegro with error messages after eg 250 footprints. Is there a "undocumented counter" for forci Allegro to be "rebooted".
  Imagine a folder of 1500 footprints, for which You need changing a properties in each footprint. It is rather anoiying to experience that one have to do this in 6 - 8 tasks, due to Allegro chrashes after 250 runs.
  Anyone who have any clues on why ?
BRGD
  Klavs.
  • kerchunk
    kerchunk over 16 years ago
     Greetings Klavs,
    Without looking over the code, my first guess would be the crashes are memory-related, perhaps due to the code not saving and closing one footprint before opening another causing Allegro memory footprint to "grow".
     As a kludge you could:
    1- modify the looping SKILL routine to read footprint filenames from a file when passed the filename as an argument, kind of like this
    procedure( fixem( ffilename)
    innfile = inFile( ffilename)
    while( gets( innline innfile) != nil
    call_yer_func( innline) ; innline contains a footprint name
    );end-while
    close( ffilename);
    );end-proc
    then divvy up your 1500 footprints amongst 7 files such that each files contains slightly less than 250 names. But that's pretty ugly. A better kludge would be a Perl script that read all the footprint names from one file, kept a count, and opened/closed an Allegro session with the -nographic option on each count % 200 == 0, feeding call_yer_func filenames as it goes.
    HTH,
    Chris Walters
    local Cadence guru-at-large
  • Romme
    Hello Chris.
      That is not the way i do open the footprint, i use axlOpenDesign() and axlKillDesign() from this i do not know if there is a more "deep" way to "reset" the allegro. Though i haven tryed the GC() command yet due to the warnings.
      Anyone out there who knows what can go wrong with use of GC(), exept that windows dies and needs reinstallation :-).
    BRGD
      Klavs.
